Using calculated formulas' in schedules to show a Family type as a yes/no
Mark_Engwirda
Message 1 of 18
Mark_Engwirda
Our window families have various glazing bar options, colonial, craftsman and nil etc.
They are controlled using a shared family type (generic models) so that they can schedule in our projects and show up in the schedules using their family names as you would expect.
What I would like to do as an alternative to having their full family names displayed I would rather just have a simple "yes/no" or a "do/blank" showing to give the schedules a cleaner look.
My issue is I don't know how to use the formula syntax to achieve this correctly.
Below are a few attempts in vain, and it may be that what I am trying to do can't be done!
Please note that the text I'm using in the schedules is an all-caps text which is why it looks different to the parameter names 🙂
See below for my 3 attempts, conditional statements are definitely not my strong point.
Replies (17)
Message 2 of 18
benschilders
To my knowlegde the formula's from Yes/No parameters in Revit only look to a value being true or false with one variable.
So for exmaple:
parameter A: this can be a value from 0-5
Yes/No parameter formula: parameter A = 2
Value's 0,1,3,4 and 5 will report the Yes/No parameter as a NO
setting Parameter A to 2 will report the Yes/No parameter to YES
Conditional statements can contain numeric values, numeric parameter names, and Yes/No parameters.
If you can share the family i wouldnt mind to take a look at it.
Also you could try to have a look at this really helpfull forum:
https://www.revitforum.org/node/1126
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
Message 3 of 18
vancikv
Conditional statements cannot analyze text values, only numbers and booleans AFAIK. So I don't see how what you're attempting could be done.
Been so since forever. There's a really old post about it if you're interested. There's an idea as well I think, but can't find it atm.
https://forums.autodesk.com/t5/revit-architecture-forum/if-statements-for-text-parameters/td-p/52145...
Message 4 of 18
benschilders
Message 5 of 18
I don't understand what you are trying to achieve, but it sounds like it's all about working with a Family Types Parameter.  It this case, a Family Types Parameter that controls the "glazing bar option" which is either "colonial", "craftsman" or "nil" - which I assume means no glazing bar option.
Sounds like you want to control what Family the Family Type Parameter uses via a checkbox which you manually check. Am I warm? Or do you want the checkboxes  automatically checked depending on the glazing bar option the Family Types Parameter uses?  OR...do you want a Text Parameter to read something depending on the option bar option?
Whatever the answer, it sounds like something I would do in the Family environment - not through a Schedule.  Any Shared Parameter value in the Family can be reported in a Schedule. That's what Schedules do best.  REPORT.
Here's some screenshots that might help. Like I said, I don't fully grasp where you are headed, but I think these screenshots will help you get there.
Message 6 of 18
Mark_Engwirda
Thanks for replying Bart Bradley, appreciate it.
So I am not trying to control the visibility of the type of mullions by the schedule, although the schedule does allow this.
What I am trying to do is abbreviate the " family name" shown in the schedule column to something shorter e.g. "Yes" if  the family type is a mullion, or "No" if the family type is "Nil"
So to recap,  instead of showing the nested family type "colonial mullions"  in the schedule, I would like to see "Yes"  or maybe "." in the schedule column as an example.
I have attached a screenshot of how the family works and what it looks like in the schedule.
Message 7 of 18
Mark_Engwirda
Thank you benschilders, the link you sent "Allow text in formulas" is pretty much along the same lines as my issue.
I have given the "Allow text in formulas" a thumbs up and apparently this is under review with 807 votes!
Message 8 of 18
As shown in the screenshots I provided: the only way to reference a Family Type Parameter Value in a Formula of another Parameter, like a Text or Yes/No Parameter, is to compare a Family Types Parameter with another Family Types Parameter.
Say, for instance, you have a 2 Family Types Parameters named "FTP 1" and "FTP 2". A Yes/No Parameter could reference a Family Types Parameter with a formula like this: =if(FTP 1=FTP 2, 1=1, 1=2).  Or a Text Parameter could reference a Family Types Parameter with a formula like this: =if(FTP 1=FTP 2, "YES", "NO").
Confused yet?
Message 9 of 18
Mark_Engwirda
Sorry for such a late reply barthbradley, I have been totally snowed under.
I did have another look at the example you provided.
I do only need a Text Parameter to read something like Y or N depending on the glazing bar option, but the choice of bars is directly selected from the mullion family parameter which is an instance parameter and not a tick box.
I just don't know how to write that formula to make it work.
Message 10 of 18
Share the family here.
Message 11 of 18
Mark_Engwirda
Hi ToanDn, window family attached.
Message 12 of 18
See revised family.  Add the parameter Glazing Bars Note to your schedule and it should report Yes No accordingly.
Message 13 of 18
Is this what you are after:
You can get there a few ways - all pretty much by using the approaches I described above.   I'll let you decide by examining what I did here. Your Family is in the attached RVT.
Message 14 of 18
Mark_Engwirda
Brilliant, thank you!
Message 15 of 18
What about me? I'm the one you provided the solution. Did you read message #5?  That's exactly what @ToanDN regurgitated.
I'm sorry I wasted my time here.
Message 16 of 18
Mark_Engwirda
Message 17 of 18
Mark_Engwirda
Big apologies barthbradely, I really appreciate what you did and all of your efforts and yes you solved my conundrum as well, just happened that I saw ToanDN's solution first 🙂
For me, the way you both solved the problem is invaluable, thank you once again.
Message 18 of 18
I appreciate the shout-out, @Mark_Engwirda.
You're very welcome.
