Rotate scope box
Rotate scope box
uschyp
Message 1 of 9
Rotate scope box
uschyp
Is it possible to rotate scope box 0.122 degrees? I try rotating the scope box to align with my grid. But when I model a wall using the scope box, the wall does not align to grid. Seem like the scope box cannot to rotated 0.122 degree. Even if i try to align to a geometry, it doesn't work. Any solution to this?
Replies (8)
Message 2 of 9
No issue here.  After rotate the scope box, did you assign it to the view?
In the example below, grid 2 is not rotated, grid 1 and scope box 1 is rotated 0.122 degree.
By the way, you only need the rotated scope box if you need to rotate the entire view.  If the intent is to align a few walls with a rotated grid, then draw the walls by pickling the grid then offset / move them.
Message 3 of 9
Another way is turning on Work plane and rotate it 0.122 degree.  Then you can draw walls at the 0.122 degree angle.
Message 4 of 9
0.122 degrees?  Why would you have a grid skewed 0.122 degrees from orthogonal?  That sounds very strange.  Do you mind me asking?
Message 5 of 9
uschyp
Yes, I did assign it to view. But when I model the wall in this scope box view selected, the wall still does not align to the grid.
Message 6 of 9
uschyp
It is because architect want the building to be parallel to the boundary line which is shewed at this angle.
Message 7 of 9
HUH?   Are you sure that's what the Architect meant?  What do you mean by "Boundary Line"?  Property Line?
Message 8 of 9
uschyp
Yes, I mean parallel to property line.
Message 9 of 9
What happens when you place Wall via Pick Lines method and picking the Grid Line?
