We have a few revit models which built from the same revit family library.
When I link them together and try to bind it. Revit automatically rename the same family
SAME_FAM to SAME_FAM1, SAME_FAM2
I know the logic to prevent the situation, same family name but different geometries.
But is there any way to get around this ?
Thanks for the reply.
But with that many families in each model.
This rename will happens all the time. It will be really a pain to manually rename them each time.
You can do it quickly with using schedule or maybe Dynamo. But if your workflow includes binding links on a regular basis then you have a bigger problem than replacing families.
