Using adaptive family to create a pendant light
5 ANTWORTEN 5
Nachricht 1 von 6
roger.ellingworth
311 Aufrufe, 5 Antworten
Hi all,
First time I have ventured into using an adaptive family, as I believe this is the only way to create a pendant light that would be placed on a sloping ceiling BUT have the light cord and shade always hang vertically...
Does anyone have any info on using adaptive families that are not just weird 4 point extrusions ?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: roger.ellingworth
If you just need to show the cord and the pendant fixture hanging vertically from a sloped ceiling then there is no need for an adaptive family.  A simple work plan based family with Always vertical option checked should work just fine.
Nachricht 3 von 6
Hi - thanks for the quick response - maybe i should clarify that i want the boss on the ceiling to follow ceiling angle (which varies) but always have the cord and light fixture remain vertical...
I can do one or the other in families but not both..!!
Nachricht 4 von 6
Host the Pendant to another Ref. Point that is hosted to the side Work Plane of the Adaptive Point and associate it's Rotation Parameter to a Host Family Rotation Parameter.
That make sense?
Nachricht 5 von 6
Like this?  There is a simple approach that requires neither adaptive nor angle parameter.
Same approach but using adaptive without angle parameter.
Nachricht 6 von 6
One more for you:
