Organize schedule
linkboy
Organize schedule
linkboy
Below is a door schedule, for door #1 the "yes/no" parameters being converted  into numbers. How can I get rid of the space btw 1 & 3 in the case no option 2? Thanks,
Replies (11)
Use Combine parameter if they are not calculated value parameters.  Otherwise, create a calculated value parameter that covers all conditions (it will be a massive line of code).
Example (1 and 3) for you to expand the formula to other conditions:
0, 1, 2, 3, 1 and 2, 1 and 3, 2 and 3, 1 and 2 and 3.
linkboy
Converted numbers are calculated parameters, not able to feed into combine parameters.
Like this?
Hide.
linkboy
Hide works for one row, next door might need option 2.
Can you work out the formula that I started?  It is long but not that complicated, mainly copy and paste code.  Do it in Notepad then copy paste to Revit.
Oh, I get what you want.  Well, if you have the stamina, you can write a formula with 81 nested if statements, then you could have all the possible permutations together in one cell - separated by commas.
Or you could forget the commas and just separate the values with a border line.
Or you could just drink.  Isn't it beer-thirty yet? 😉
linkboy
yes, I had one using conditional formula. But your (and ) is simple. Let me try.
Are you seriously considering trying to tackle this:
=if(and([ADA Entry (No. 1)], [not(Card Reader (No. 2)]), if([Panic Hardware (No. 3)], "1,3", if(…so on and so forth 80 more times to catch every possible premutation…,””).
Yeah 8 conditions to cover all you ever need.  Simple enough.  Don't let others dumb you down by persuading you need to add more.
YYY
YYN
YNN
YNY
NNN
NNY
NYY
NYN
Guess you're right. I was thinking permutations like Rubik's Cube.   Actually, it's combinations- just eight of them.  That's doable.
linkboy
thanks for the list.
