User Defined Parameter Set Not Exporting To IFC
LeeUUSLM
LeeUUSLM
Hi All,
I have been trying to create a user defined property set to improve our IFC export from Revit following blogs and guides online I have created the attached.
I must be missing something though because they new property sets havent been created when converted to IFC.
Could some one take a look and see if I have made a basic error ?
Thank you in advance !
you have not deleted the " # " at the beginning of most of the lines in the file. these mark the lines as comments which mean they are ignored. try if it works after deleting them. could you also post which version of the revit exporter you're using?
