Use Topography to cut solid objects
I have a project where I am fabricating large boulders. I have a topography surface, and know that footings for the fabricated boulders must be located approximately 2' below grade. How can I use a topo surface to cut the boulders I have designed so that I may find out the volume of concrete I need? This is also a crucial step in my construction drawings. I designed the boulders in AutoCAD and imported them to Revit, where I did the rest of the work, so it would be easiest to modify them there.
Read the tutorial below:
MARCELLO SGAMBELLURI AB3340: Make Hardscape Follow Site Topography and Site Topography Follow Hardsc...
Or, you can split the topo surface following the boulder footprint, create a schedule with a calculated value to get the volume based on the surface area.  You can move the splitted area down 2' if you want.
Viveka_CD
Hi @Anonymous
Try to create the topography as a custom in-place family. Then you can use a custom void shape to cut the topography.
Revit lists the volume properties in the Properties palette.
See HERE for information on how to Reporting Cut and Fill Volumes on a Site.
Can you share a screen-shot of the section with your boulders and site?
HERE is screen-cast by @Lance.Coffey on how to cut sides in a topography.
If you find this post has solved your problem, please click on 'Accept as solution' to help others with similar questions.
Albert.Maduro
Thank you for the reply, this helps alot
Anyway, the link you gave does not work, so I tried to google the title and I found the working link for the tutorial video
https://www.autodesk.com/autodesk-university/class/Make-Hardscape-Follow-Site-Topography-and-Site-To...
