Upload google doc (.gdoc) to BIM360
4 REPLIES 4
reut.h
303 Views, 4 Replies
I've been trying to upload a Google doc (.gdoc) to BIM360 but I keep getting an error "Upload Failed" (See attached screenshot).
Is it possible to upload Google Docs instead of Word Docs? If not, is there a workaround?
Labels (4)
4 REPLIES 4
ralphdenhaan
in reply to: reut.h
To my knowledge, BIM ACC doesn't support uploading files with the .gdoc extension. The only solution I'm aware of is downloading the .gdoc file as a Word (.doc) file and then proceeding.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
reut.h
in reply to: ralphdenhaan
Thank you for you replay,
I have seen this feature but it didn't work. Are you familiar with this?
ralphdenhaan
in reply to: reut.h
That is for linked files:
https://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-1B49B17A-12C3-47A1-9AAC-EFC46AF9D7AD
However, this feature also doesn't provide the capability to upload files with the .gdoc extension.
reut.h
in reply to: reut.h
That's unfortunate, sounds pretty basic to have.
Thanks.
