I've been trying to upload a Google doc (.gdoc) to BIM360 but I keep getting an error "Upload Failed" (See attached screenshot).
Is it possible to upload Google Docs instead of Word Docs? If not, is there a workaround?
Solved by ralphdenhaan. Go to Solution.
To my knowledge, BIM ACC doesn't support uploading files with the .gdoc extension. The only solution I'm aware of is downloading the .gdoc file as a Word (.doc) file and then proceeding.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Thank you for you replay,
I have seen this feature but it didn't work. Are you familiar with this?
That is for linked files:
https://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-1B49B17A-12C3-47A1-9AAC-EFC46AF9D7AD
However, this feature also doesn't provide the capability to upload files with the .gdoc extension.
