Upgrading message when opening Revit model
Im Trying to open a rvt file in my 2016 version and it will tell me that file was creadet using a later version but then i go and open it on 2017 and it will show the upgrading model dialog. I serioulsy haver no idea what to do because all the other models in this project are 2016 and we are not ready to make the migraion just yet.
Any ideas?
ennujozlagam
Hello are you opening the file from window explorer? Try to open your Revit program first then open your file. Thanks
Viveka_CD
Hi @Anonymous
Thanks for posting on our forum! It's been a while and I'm checking back to see if you are still facing this issue.
When you open a model from an earlier release of Revit, the model may need to be upgraded to the current release.
See HERE for more information.
To open a Revit file, use any of these methods
When you open a Revit project file, you can set these options
Please let me know if you have additional questions.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
