Revit Architecture 2010 keeping it alive
We have run Revit Architecture 2010 on Windows 10 for a couple of years (initially on XP and subseqently on Windows 7 before enforced upgrade to 10) - we had initial problems but after a clean reload of Windows it has worked fine.... until yesterday when it failed to load with the error message <Revit has stopped working; Windows is looking for a solution to the problem>.
We recognise that this version is long in the tooth and that there is an incompatibility issue between this version of Revit and Windows 10 but it has previously worked OK therefore logic suggests it might do so again. We are seeking ways of keeping the program alive at least for another month until we swap out.  Any help (short if subscribing to Revit 2018 today) would be most gratefully received!
regards Barrie
L.Maas
If it was working until yesterday the cause might be some windows (or other) updates. You could see if you go to a restore point before yesterday.
You also might consider to  see if you can install windows 7 or 8  and see if you can get it installed there.
Louis
Please mention Revit version, especially when uploading Revit files.
