Upgrade a set of Central Models
I want to upgrade 3 central files, structure, mep, and arch from 2014 to2017. But keep it a central file. How would one do this?
Assume you will be working on 2017.
- Archive the 2014 files to a different folder.
- Open 2014 files in 2017 and save to new centrals, one by one. Keep the file names so that the links stay intact.
- Close them and re-open to create new local files.
Thanks! Yes, 2017. This may be silly to you, ha!, but just to verify, I am assuming you just double click or drag the file into the 2017 window to upgrade, versus using the open-project then selecting any options such as "detach from central, is that correct?
RDAOU
@Anonymous
Make it a habit (more of a bible verse)
   "Thou shalt not Double Click to open a Revit File"
Always open Revit first then either/or
  1. drag and drop in Revit
  2. open from application menu
SWEET
