Update rvt project 2016 to 2018, links not apear
ctga.geral
ctga.geral
Hello good day,
In the company where we work, we have the subscription of the complete package subscribed, we had the revit 201, the problem is now when we update a project for 2018 the links do not see the main document (as the attached figure)
I have already followed your steps that update by doing audit to * .rvt.
I would like technical support.
Francisco Pereira
Viveka_CD
Hi @ctga.geral
Sorry to hear that you are facing issues.
A few questions to better understand the issue:
  • Can you confirm if you have the latest updates installed for Revit 2018 from your desktop app?
  • Are you using a server-based central mode?
  • Did you process a backup copy of the main model before the upgrade process.
  • Is this issue specfic to a user/ machine?
Looking forward to your reply update.
ctga.geral
Hello and thank you for your help.
I answer your questions below.
Yes, We have the latest updates.
No, we are using local files.
Yes, we have a backup of the original files.
No, this occurs in every user in our company.
Viveka_CD
Hi @ctga.geral
Thanks for getting back.
Since this is not user specific, the issue is related to the upgrade process.
Can you try the below for me and see if it helps?
Looking forward to hearing from you.
ctga.geral
•Open each Revit link separately, audit/purge the files individually and unload, reload again one by one. After linking one file see if it appears.
Not appear, and get message error
•Review Orphaned Elements from Linked Models
Not appear
•Try a repair of Revit.
Yes, i repair
•Are the linked Revit files from other consultants?
No.
tino.freitas
Hi @ctga.geral
at this point the best course of action would be for you to send us the files. You can do so through the case or through the A360 Drive folder that we shared with you.
Looking forward to hearing from you soon!
Tino Freitas
Technical Support Specialist
AutodeskBuilding/playlists | Contact Autodesk Support
