Unrecoverable Error
Unrecoverable Error
jahillegas
Unrecoverable Error
jahillegas
I was working in a revit model this morning and got this error message. I have attached the journal file, I really hope this file is recoverable.Revit Error.PNG
RDAOU
@jahillegas
Did you try to Audit the file on Open?
Is it a Workshared model?
jahillegas
It is not a workshared model. I did run the audit upon starting, and nothing popped up nor did it resolve the issue.
ennujozlagam
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
RDAOU
@jahillegas
You have a better GPU on this machine Quadro GTX 5000  -  A good card, I have a similar one on a different workstation but I would recommend that you disable use of hardware Graphics Acceleration (File >> Options >> Hardware)
I went through the Journal
  1. You have a plug-in Called Revizto causing an API-Error (Unload it)
  2. The crash occurred after registering system exception for the elements marked in the below image. Elements could be in your main model or a linked. Check your model /select elements using the registered ID and delete from model...
  3. Recreate the element from scratch then test again
FacebookGroupMember
Save often and work share.
