Unknown Import Symbol, Cannot Render A Material
staylor0528
staylor0528
Hello I am trying to add a material to this chair from a childrens furniture company. It was saved as a rfa file so I assumed when I downloaded and opened it that it would be such.
However, it is a unknown import symbol instead. Which leads to my problem, I know how to use object styles to add materials for sketchup and other imported objects but this object does not have any object styles...
It was saved under specialty equipment but when I check object styles and imported symbols, there is only the generic and Level 0 (aka nothing if you know what Im talking about) on the imported symbols.
Also, I tried exploding the elements, and it disappeared so thats a no go.
I cannot figure out what kind of object it even is to try and solve the problem. Any help?
Post the family here.
...otherwise, all we can do is guess.
staylor0528
Here you go boss, appreciate it for my senior project 🙂
You're out of luck. Be easy enough to model it Revit though.
