Wall Fill in Coarse Detail Level
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
PhilvK
221 Aufrufe, 2 Antworten
I have walls set to have a solid fill in Coarse Detail Level. Walls with layers defined are not displaying the fill, while only the Generic walls do. This is happening in one particular file - all the walls however display properly when I copy and paste them into another project. Any idea on what setting to look for in the offending project?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: PhilvK
Is there an override applied to the View?
Help | Element Visibility Override Hierarchy | Autodesk
Nachricht 3 von 3
PhilvK
als Antwort auf: barthbradley
Not where you show, but the setting in the Properties window was set to Medium. Thank you! I should have looked there first.
