Unit Separator To change Dimension values
2 REPLIES 2
ryanbiljan96
200 Views, 2 Replies
I am currently working on a project where I am creating drafting view of AutoCAD drawings into Revit to create sheet view for a blueprint. Because the drawing in AutoCAD were not drawn to scale I had to manually change the value of the dimensions when I created them in Revit. I used the insert US unit separator override to put in a number as a dimension when I would replace the dimension value with text. The problem that I am having is that when I export the sheets to adobe little boxes pop up in adobe where the invisible unit separator would be. Is there way I can override the dimensions in another way or a way to turn off unit separators when I export the project sheets to adobe?
2 REPLIES 2
in reply to: ryanbiljan96
I use right click > insert Unicode control character > Zero width joiner
That seems to work reliably.
Steve Stafford
