Unique Value in Family Parameter
se.ha
Advisor Advisor
se.ha
Hello community
I am currently working on a Revit family and would like to implement a warning that is displayed when multiple instances of this family have the same value for a specific parameter. Similar to door or room numbers, I want to ensure that the values are unique. Any ideas?
Thank you
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
Mike.FORM
If I am understanding this correctly you are wanting to compare a specific parameter (could be a length, an integer, text, etc.) of one family instance or type and see if another family instance or type has the same vale?
This can be done in using dynamo but I do not have the experience to help with this one.
There may also be a add-in that does this.
se.ha
Yes. The user has to enter a value und Revit should check if another instance of the family already has the same value. Like the "Elements have duplicate "Mark" values"-warning in doors.
I know how to do it in dynamo - but I need instant feedback for my co-workers.
se.ha
Mike.FORM
The only other way would be to use a schedule which is sorted using the parameter you are checking and then uncheck the itemize every instance so it groups them and then add the count parameter to the schedule.
