Uniform texture of roof of skylight
someone can hep me to find the right command to uniform texture between roof and skylight?
I go in "family types" in skylight family but don't seem is the same after I upload the family in project with texture of skylight as in roof.
Thank's
RDAOU
@Anonymous
Fenster Rahmen = Window Frame
Fenster Flügel = Window Panel
Gaube Wand = Dormer Walls
Gaube Dach = Dormer Roof
I guess you are looking to change material of the last!
@RDAOU much easier than I thought.
Don't even have to go in the "family type" of the dormer. Just click on the dormer in the project and click on property materials.
Thank's!!!
 @Anonymous; I noticed this before and meant to say something.  You really should use a Model Hatch Pattern, instead of a Drafting Hatch Pattern, to represent your Roof Shake.  A Model Hatch Pattern wouldn't get distorted the way yours is showing.  Do you have a "Shake" Model Pattern? You should. If you don't, I can post one.
@barthbradley post, please.
Thank's
RDAOU
@Anonymous
Click the image below to watch...you already have the Model Pattern in your project, use it instead that Drafting pattern
@RDAOU @barthbradley
ok this is my render
is not very much
can you help me to set the appereance properties at least for roof and walls (wood and stone), please?
Cheers
