Ungrouping in Revit
Ungrouping in Revit
Ungrouping in Revit
I have an issue with my Rhino file its a 3D file, when I insert it as a Rhino file, somehow I cannot ungroup it in Revit?
I tried it in other Software's and its fine as soon as I ungroup it, it works fine and I can move lines and objects freely.
Does anybody have any idea or solution for this problem?
Hopefully I can find a solution for this as soon as possible.
Thank you.
What do you mean by "ungroup" it?  Do you mean "Explode" an imported .sat file?  Tell us more about your workflow or share the RVT.
Ungrouping the elements so I could move around object and lines that I imported from Rhino as a 3D file into Revit.
You can't.
MostafaElashmawy
The only way is to save it from  Rhino as IFC then open the IFC in Revit.
However, in that way, some elements may not be exported.
Mostafa Elashmawy
s.borello
You can NOT.  You would need to import and then explode... not my preferred workflow.
