I delete a level and all my floor disappear [ it was connected in this level] how I can UNDO this?
The back button is not enable..
Thank you
Solved by Alan.johnson1970. Go to Solution.
You could use the backup file, but that depends on:
When did you last save?
How much work have you done since your last save?
If the back up file is not an option and you cant undo the delete you will have to re model the floors
