Staircase Graphic Issue In Revit 2018
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
mujahid.kadri
372 Aufrufe, 2 Antworten
 staircases is not showing properly in 3D view
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: mujahid.kadri
Change stair structure underside from smooth to step.
Nachricht 3 von 3
This happens to me too. If you set the underside surface to stepped instead of smooth in the run type properties of the staircase it works fine.
Alternatively you can make it as a model in place sweep
edit: Do'h! @ToanDN beat me to it while i was typing!
