Underlay showing higher than the floor plan selected
4 REPLIES 4
khopwood
597 Views, 4 Replies
This is an odd problem I've never run into. In trying to underlay the First Floor Plan on the foundation plan, it's showing the second floor/roof. I've tried as many different configurations as I could as far as changing the top range level in conjunction with the orientation; and even the base range level.
I'm stumped because I didn't change anything in the view range on the first or second floors and I've never had this issue before.
Labels (4)
4 REPLIES 4
RDAOU
in reply to: khopwood
@khopwood
Can you provide
  1. a screenshot showing a section with the levels
  2. a screenshot showing the View Range of the foundation level
khopwood
in reply to: RDAOU
The view I'm having trouble with is actually the "crawl footing" view.
I have the top of my foundation wall set to ground level (-1'-0"). also, Crawl footing level refers to the bottom of the footer, crawl foundation level refers to the bottom of the foundation wall.
RDAOU
@khopwood
I am not exactly sure why do you have duplicate levels???
Top of Basement wall and Ground Floor are the same? if yes delete 1 of them ... Having 2 levels there will mess up your underlays (Repeat for all other levels)
Trying to replicate what you have:
GIF 1...Using single level (No duplicates) Underlay functions normally
GIF 2 - Adding a duplicate level at Ground Floor - Underlay malfunctions
