Underlay showing higher than the floor plan selected
khopwood
khopwood
This is an odd problem I've never run into. In trying to underlay the First Floor Plan on the foundation plan, it's showing the second floor/roof. I've tried as many different configurations as I could as far as changing the top range level in conjunction with the orientation; and even the base range level.
I'm stumped because I didn't change anything in the view range on the first or second floors and I've never had this issue before.
RDAOU
@khopwood
Can you provide
  1. a screenshot showing a section with the levels
  2. a screenshot showing the View Range of the foundation level
khopwood
The view I'm having trouble with is actually the "crawl footing" view.
I have the top of my foundation wall set to ground level (-1'-0"). also, Crawl footing level refers to the bottom of the footer, crawl foundation level refers to the bottom of the foundation wall.
RDAOU
@khopwood
I am not exactly sure why do you have duplicate levels???
Top of Basement wall and Ground Floor are the same? if yes delete 1 of them ... Having 2 levels there will mess up your underlays (Repeat for all other levels)
Trying to replicate what you have:
GIF 1...Using single level (No duplicates) Underlay functions normally
GIF 2 - Adding a duplicate level at Ground Floor - Underlay malfunctions
