We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Underlay settings do not provide the desired result, what can be done?
eliav5221576
eliav5221576
Hello everyone,
Im trying to use underlay to see the floor below (I'm working on a complicated project),
but I don't see the whole plan below,  some elements is hidden, and I can't fix it.
Does anyone have a recommendation on what to do? Maybe an add-on for pyrevit?
I need to get to the point where I can see the entire plan below perfectly.
Thanks for the help
Rana_HamedEREMS
Hi Eliav,
check the solution for this issue in the link, I think it will guide you perfectly. https://forums.autodesk.com/t5/revit-architecture-forum/override-underlay/td-p/7217172
Check your View Phase/Phase Filter. Maybe you're in a Phase prior to all those elements.
eliav5221576
thank you for the answer! I couldn't understand all the steps, he wrote briefly
eliav5221576
I checked, that's not the case
