Underlay Not Showing Walls Above
BigPicture045
BigPicture045
DESCRIPTION: Currently working on a crawl space plan. I am trying to set the underlay to view the first floor (right above the crawl space). Setting the underlay feature does not reveal the walls on the first floor above.
Checked so far:
-Phase filter (phases are default and not used in this file)
-View Range
-Hiding/deleting the first-floor floor
-Hidden Elements
Image description: Note the double joist locations should correspond to a wall above. I am unable to line up the double joist without view the underlay of the walls above.
The file is attached.
Shouldn't the Underlay be set to First floor?  e.g. Range: Base Level.
Underlay Range:
Base: 1st floor
View Direction: Looking down
