Underlay: Floor above current floor
Marcus.Isacsson
Marcus.Isacsson
Hi fellas!
I'm trying to accomplish something seemingly simple but I can't get it to work.
I've created area plans where I've colored (filter) load bearing walls and would like to see the floor above current one.
Been fiddeling with underlay but it doesn't seem to show the floor as intended...
(look up etc.)
What could be wrong?
Alfredo_Medina
  • In your image, the level for the underlay says "None". It needs to be the level above.
  • Also, I think is not necessary to use a view filter to differentiate bearing walls from non-bearing walls. Instead, you could change the discipline of the view to Structural. That will show you only the bearing walls.
