Unable to use offset function for Grid line (Urgent!)
7 REPLIES 7
Message 1 of 8
3842 Views, 7 Replies
Anyone can advise how to solve as I am using 2020 version to create Grid line and unable to offset.
I have chosen numerical and checked copy box after selecting offset function.
The offset icon appeared but unable to see dotted line to offset as per instruction.
Kindly advise if anyone encounter the same issue.
Moontulay
7 REPLIES 7
Message 2 of 8
kadmonkee
copy them and enter the distance you need, it is a simple exercise
some things can't use the offset tool
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 8
Are you using the "Pick Line" method?
Message 4 of 8
in reply to: barthbradley
Thanks for the reply, I did not use pick line. But just use normal line to create Grid line.
It happen only to Grid line but other wall I can able to offset.
Do you encounter the same issue before?
I have snap shot for our easy reference and advise.
Message 5 of 8
kadmonkee
the OFFSET tool is not available for offsetting Grid lines
but when you want to Place a new grid line you can use the offset option and pick lines selection to hover over the grid line to be offset from.
thank you
Message 6 of 8
s.borello
Offset for gridlines will only work if you choose the pick line option.
Message 7 of 8
kadmonkee
in reply to: s.borello
offset for grid lines option and pick lines is only available when Placing a new grid line.
no pick lines option using the OFFSET command
thank you
Message 8 of 8
in reply to: kadmonkee
thanks for the response. It's works.
