Good afternoon. I linked a CAD file into my model and lines shown are so thick I went to the CAD file to make lines thinner, however they are shown the same. I thought it was a linked file issue but when I was trying to sketch a floor: sketching lines are also shown very thick. any solution please?
thank you
Gelöst! Gehe zur Lösung
Gelöst von GoldenGateNetwork. Gehe zur Lösung
I have already figure this out
thanks
Object Styles governs the lineweights assigned to categories globally (all views). Then each view can be altered using Visibility/Graphic Overrides. Linestyles govern the appearance sketch lines (like in Floor sketch) and those are found under the Manage ribbon tab > Additional Settings > Linestyles.
DWG files are linked/imported according to the Import Lineweights settings - Insert ribbon tab > Import panel > Import Line Weights "button" (tiny arrow pointing between 4-5 o'clock). Revit maps the colors (DWG color number) to a Revit Pen (lineweight). Lineweights are governed by the Lineweights dialog under Manage ribbon tab > Additional Settings > Lineweights.
Steve Stafford
