Unable to see elements in section view of the linked IFC converted Revit model
Radish_G
Message 1 of 16
Radish_G
Hi Community,
I converted an ifc model to Revit model and linked into a MEP model.
I manage to see the elements in the plan & 3D view, but when I make a section view I cannot able to see any elements.
Can someone help me fix this issue?
Regards
Radish G
Replies (15)
Message 2 of 16
ennujozlagam
check any view template assigned , try to set to none? or check setting of  your section view line far clipping from properties. thanks
Message 3 of 16
Radish_G
Hi @ennujozlagam ,
No view template assigned.
Far clip set to "Clip without line"
Regards
Radish G
Message 4 of 16
Radish_G
Hi Community,
File attached for your kind review.
I attached both IFC & the converted RVT file.
Regards
Radish G
Message 5 of 16
Radish_G
ifc
Regards
Radish G
Message 6 of 16
Phasing?  Set Phase Filter to "None".
Message 7 of 16
Radish_G
Hi @barthbradley,
Yes, the phase filter is set to "None"
Still cannot able to see
Regards
Radish G
Message 8 of 16
ennujozlagam
I tried and checked, when I created a new section line the section view will appear, but when you zoom to fit your view will disappear, which means you have an object or lines that far away from the main model. To check this you need to check your if linked and Revit file to delete those objects. Thanks
Message 9 of 16
Radish_G
Hi @ennujozlagam,
It is because of the level line.
While I zoom fit I can able to see the entire view, but not the elements.
Regards
Radish G
Message 10 of 16
ennujozlagam
check out this please see attached and one more thing check your phasing and if you want to see the view activate your crop view/crop region visible/annotation crop. thanks
Message 11 of 16
Radish_G
Hi @ennujozlagam,
I checked the model you send to me.
It's in the same condition.
Regards
Radish G
Message 12 of 16
Message 13 of 16
ennujozlagam
So, what do you really want? Your issue is cannot see your section view? Did you open the section view?
Message 14 of 16
Radish_G
Hi @barthbradley,
I get you,
but while I check the model (uncropped view)the max length of the element is 464 meters only.
Which means all the elements lie within the 16Km range.
Regards
Radish G
Message 15 of 16
Radish_G
Hi Guys,
I manage to spot the problem.
As you guys said earlier, its a phase problem.
I dod the following to fix that.
Thank you so much for your time and support.
Regards
Radish G
Message 16 of 16
@Radish_G wrote:
Hi @barthbradley,
I get you,
Yes, you are right. I'm examining your file now. You are within the limits allowed -- albeit your Project Base Point seems to be an exorbitant distance from the Model.  Currently, I'm having difficulties recreating your issue. So far, every cross-section I've made displays correctly. Are you sure that the section crop encompassed everything you wanted to see?
