Edit the void extrusion in 3D
11 ANTWORTEN 11
Nachricht 1 von 12
mairh_tsek
3098 Aufrufe, 11 Antworten
Hello all,
YHow is possible to control the top and bottom for an extrusion void in 3D? Until yesterday I ewas able to see the void form in the 3D and to adapt its height.
Today the void  is not visible in 3d..
Any tip?
Thank you
11 ANTWORTEN 11
Nachricht 2 von 12
ennujozlagam
als Antwort auf: mairh_tsek
you can refer to this LINK and see if helps .thanks
Nachricht 3 von 12
mairh_tsek
als Antwort auf: ennujozlagam
I create the void in the project not in a familly
Nachricht 4 von 12
ennujozlagam
go to Visisbilty graphics > model categories > generic model > untick ifc opening . you can also  do that in the link file just change to custom > VG. thanks
Nachricht 5 von 12
joe_keogh
Hi @mairh_tsek
First which category did you use to create the Void?  If you used Mass, can you check that the Mass is set to visible on the Massing and Site Tab
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Nachricht 6 von 12
dferreira-blackwell
Set mass to visible as the post above, also check your visibility settings under VV/VG for Mass, turn on the Revel hidden element button (light bulb thingy) at bottom of the window.
Or wherever you used your void to cut select that edge and tab through it to find the void.
Nachricht 7 von 12
mairh_tsek
als Antwort auf: dferreira-blackwell
Thank you for your answers.
I created the void as a Model-in Place...finally I noticed that in the 3D with the section box I was cutting in a different level..
Nachricht 8 von 12
I'm not sure how you would "see" a Model In-Place Void in the Project, since the Void would need to cut something (and therefore become invisible) before closing out of In-Place Component.
Nachricht 9 von 12
mairh_tsek
als Antwort auf: barthbradley
I wanted to see it before ending the option in order to ajust the height easier.
After the ending of this option there in not any way to see the cutting part?
Thank you.
Nachricht 10 von 12
Thank you.
Add labeled dimensions to the void to control its sizing.   No different from what you'd do if it were a loadable family.  You can add parameters to an in-place just the same as you do in a loadable family.
Nachricht 11 von 12
You can tab where the void cut the element to select the void.  You probably won't see the entire orange void form as you expected but nevertheless it can still be selected and edited.
Nachricht 12 von 12
mairh_tsek
Thank you for your answers., the problem was that in 3D view I didn't had the correct level.
' Add labeled dimensions to the void to control its sizing. '
Just to know..Is it possible to add labeled dimensions in a project or only in a family?
Thank you!
