Unable to Rotate
Unable to Rotate
anis.123
Message 1 of 11
Unable to Rotate
anis.123
I want to rotate a girdrer such that it will become inclined. But as soon as i want to rotate it an error occur saying that "Can't draw because Work Plane is at a very sharp angle in this view. Go to another view or redefine the Work Plane."
Replies (10)
Message 2 of 11
Have you tried to change the elevations of start and end?
Message 3 of 11
anis.123
This option is not available!!!! when I place a beam this option is
available but when I try to place girder this option is not available.
Message 4 of 11
Sahay_R
Can you set the Workplane in the view you are trying to rotate the girder?
Edit - retry placing the Girder. When I tried, both options were available.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 5 of 11
I can't seem to replicate it.  A girder can be adjusted without any problems.
Message 6 of 11
anis.123
Can you please expalin how this can happen!!!!
Message 7 of 11
Sahay_R
Good question. Can you share a file? Easiest thing - CTRL-C and CTRL-V your girder and its supports to a blank file and share.
Rina Sahay
Message 8 of 11
anis.123
I an trying to attach the file but it is taking a very long time
Message 9 of 11
anis.123
I have attached the file!!!!
Message 10 of 11
anis.123
I modeled the girder by making its family !!!! The already present families are showing this option but the families which I modeled are not showing these options
Message 11 of 11
You need to create the family from the structural framing family template, not the generic model template.  See attached.
