Unable to place components at angel wall in Revit 2023
4 REPLIES 4
Adey001
312 Views, 4 Replies
Hey guys, Hope you are doing great. I am a beginner in Revit and I want to place a tub at the corner of wall but both walls are at angel and hence i am not able to place the tub correctly. I tried to find the solution but no success yet. I will be thankful for your help. I have attached the picture as well as the rvt file.
4 REPLIES 4
andr3sant0s
in reply to: Adey001
Hi @Adey001
Press space until you get the reference you want when placing the tub!
Please use Accept as Solution and like/Give Kudos as appropriate to further enhance these forums.
Adey001
in reply to: andr3sant0s
i get the reference for only one wall. I need to place it in a symmetry at the corner of a wall. (as seen in the picture)
You mean like this?
If so, the way it's done in real life is that the tub platform is framed separately from the tub. Model your tub platform with Wall Type and Floor Type.
Adey001
in reply to: barthbradley
thanks..
State of Sustainability Webinar
