- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am working on a project in Revit 2015 that is a shared project on our local network. I am having issues with opening the central file from within Revit like I'm supposed to. I open Revit 2015 and the main screen opens and I click "Open" under the "Projects" category, search for the central file on our network drive, and then click "Open" with "Create New Local" checked as normal. I then click "Overwrite Existing File" as we're supposed to when working on this project and I get an error message that reads, "Revit could not create local file from 'our network drive file path'. This could be due to a network problem. You can try again or contact technical support". It also won't open and gives me the same error message if I go to the "R" dropdown menu and attempt to open from there.
The kicker here is that I can go into Windows Explorer and find the same exact Revit project file and double click on it from the network drive and it will open in Revit 2015 no problem. I am even able to sync with central.
I know it doesn't seem like a huge deal, but it's rather inconvenient...and I don't feel comfortable opening files solely from Windows Explorer. This is the only shared (multi-user) project file that does this. All of the other ones will open within Revit and in Windows Explorer fine.
We've tried to go through what we know to figure out why this is happening:
- Checked network connections - computer is connected to network and has access to all drives on network
- I have admin credentials
- Project file is NOT read-only
- Permissions on file are 'full control'
- Can open up the file without creating a new local (aka detaching from central) but this defeats the purpose of trying to open the file...
- Tried to audit the file via open prompt and still had no luck opening it via Revit-->Open
