unable to lock/snap a spline (therefore unable to flex with parameter(
heichan88
heichan88
I found that spline ( mass or generic) is unable to be locked or snap to the nested references, so therefore unable flex with the paraneter change, and I did not find any way to align .....
But in adaptive, spline can be 3D-snapped....  nd if I make a  parametric spline in adaptive, it is limted not be able to used for other models (generic, etc)....
Please advice
Sounds like the nested RLs' Reference Property is set to Not a Reference?  Set it to Strong or Weak.
Create ref points and constrain them, then create spline thru those points.
