UNABLE TO LOAD A FILE AS A GROUP
Maurizio.Lombardo
Maurizio.Lombardo
Hi all,
I have created a group for a layout apartament (internal walls, furniture etc.) and saved as a group. If I open another project and try to load the file as a group it says -UNABLE TO LOAD FILE "X" AS A GROUP.
Do you have any idea how to resolve this issue?
Many Thanks
Revit Architecture 2015
u can first link revit model then bind that model in ur working model
Lance.Coffey
Autodesk Support
Autodesk Support
If you successfully saved the group as a separate RVT file, you could use the steps in the following article to identify what is preventing it from being loaded as a group:
How to check if a particular family or family instance is causing unexpected behavior
Lance Coffey
Technical Support Specialist
sorry to resurrect an old thread,
we are having this issue in 2018 any ideas.
all working fine until recently! 2018.3 upgrade perhaps?
