- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Masters!!!
I want to create a model pattern as shown in image.
I created a pattern as below,
*Tile Sheet,
;%TYPE=MODEL
0, 0, 0, 0, 3
0, 0, 5, 0, 3
While loading it into Revit I cant use the import scale as 1 in Add Surface Pattern dialogue box, if import scale is set to 1 it show some error like "The pattern with the values you have supplied is too dense. Try increasing the Line Spacing". So I tried a scale value as 5, now it works fine, but the problem is the pattern not worked as I created instead it works as 5 10 5 10 . . . (i.e it takes the value I entered into import scale). Also I tried with other values such as 10, 15 etc., it doesn't works as I needed. Please help me to get rid of this.
If this is not too clear please let me know. Thanks in advance.
