I was wondering if it is possible to label structural knots in Revit using keynotes. I think it is not possible because there is not such a BIM "joining" element between a void and a pilar (for example), so it is impossible to label an element that does not exist.
The only way I find is to create an invisible generic model and place it in the joints i need to label.
Does anybody find a "cleaner" way to do this?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You can place a user defined keynote...these are the existing categories, or you could customize the keynote file and add what you need.
Revit_Wisperer, that is what i was about to do. Tagging the generic model I can solve this, but as I see it, it doesn's seem elegant enough (the part of the generic model I mean).
ToanDN, that could be the only way, and more accurate than the generic model. To place an "empty" detail component while it is not defined, and to model it when (and if) the moment comes is the best idea I think. Meanwhile I could tag those invisible elements with keynotes.
Thank you!
Revit_Whisperer, I can't find the way to tak the endings of an element such as a pilar or a beam. Thank you anyway!
I have found a tool that may help get this problem solved. It is called Beam Annotations Tool.
