Unable to create central model /enable workset
1 REPLY 1
6805 Views, 1 Reply
See attached model -
Unable to create central even after renaming. Model was created from detached central model with discarded worksets.
Tags (3)
1 REPLY 1
Darin.Green
Darin.Green
Hi @Anonymous,
I was able to recreate the issue you're having. I've attached a screencast of the process I used (Keep in mind that I use C4R so I had to use the Collaborate button instead of worksets). It does the same thing as worksets when creating a local collaboration central model.
If this information was helpful, please consider using the Accept Solution
Hi @Anonymous,
