Unable to change camera images to black and white
Have taken some camera photos and added them to a sheet. Is there anyway to change to black and white or any way to change the model to black and white and get rid of all the color? Thanks
ennujozlagam
@Anonymous hello, i don't think that is possible but you can use photoshop to change the colour and reload again in revit. thanks
Edit the photos in some photo editing software and change them to grayscale or black and white. As for your model, do you set the views to shade or realistic visual style? Change them to hidden visual style. If you only need to print out as grayscale, then you don't need to change the model, just set the output to grayscale under print settings.
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member! Warm Welcome to the Autodesk community! Smiley Happy
As suggested by @ToanDN and @ennujozlagam the image can be changed to 'black and white' using image editing software:
Adobe Photoshop
Irfan view
Photoscape
movavi photo editor (classic black and white images)
fotor
Within Revit you can insert your image as a decal, but that does not make it 'black and white' though you can modify the settings see below:
Please see print settings in Revit HERE
As suggested by @ToanDN you can print in monochrome as:
  • Black Lines: All text, non-white lines, pattern lines, and edges print in black. All raster images and solid patterns print in grayscale. (This option is not available for publishing to DWF.)
  • Grayscale: All colors, text, images, and lines are printed in grayscale. (This option is not available for publishing to DWF.)
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
@Viveka_CD wrote:
Hi @Anonymous
Adobe Photoshop
Irfan view
Photoscape
fotor
Thanks for your guide. I have the same question and this works!
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member.YAY!  Welcome to the Autodesk Community! Smiley Happy
Glad to hear that the recommendations worked for you! Smiley HappySmiley Happy
Let us know if you have additional questions.
