unable setting the hotkey "pp" for pin
bim666
bim666
Hi everyones
I can setting the hotkey fot pin with "ii" "nn" or "ee" and it works
but "pp"
It's usually done when you hit the hotkey,not showing the command text
help...
Revit 2022.1.8.32 tw
arq_42
"PP" is the shortcut for the Properties panel.
Try removing it from the panel before set it to Pin.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
bim666
thanks for your notice
I figure it out
I replace it from pp to ppp already
but it still needs to use arrow or press space bar to finish it
It's a bug
azad.Nanva
delete the PPP for Properties panel or PP1,PP2 or somthing like that.
bim666
Thanks, I changed it to P2P and it works perfectly.
It's a bug
arq_42
Actually, it's not a bug.
If I set one shortcut as "AA1" and another as "AA2" in a different tool, when I press "AA," Revit will wait to determine if the next key press is 1 or 2.
The same thing happens if I set one as "AA" and the other as "AAA."
When I press "AA," Revit will wait to determine if I want to stay there (spacebar) or continue with the shortcut.
