U shaped stair by sketch problem (gap)
8 REPLIES 8
Message 1 of 9
cesarcoraini
638 Views, 8 Replies
Hey everyone. I'm having a problem with my U-Shapep Concrete Stair.
I don't know why, but there is a gap between two steps and i don't know how to connect the steps.
Can someone help me pls?
Have a nice day!
8 REPLIES 8
Message 2 of 9
RDAOU
in reply to: cesarcoraini
@cesarcoraini
With only that info provided...I would suggest that you adjust the structural depth
Message 3 of 9
cesarcoraini
in reply to: RDAOU
Hey @RDAOU ! Thanks for the help!
I tried to adjust the structural depth and the gap disappear, but the steps are slightly connect,
Which information do you need more? i can try to send more things.
Sorry for bother you.
Message 4 of 9
RDAOU
Well you could post the stairs ... the rvt file
Message 5 of 9
cesarcoraini
in reply to: RDAOU
Ok! Thanks for the help.
Message 6 of 9
Here is a revised stair with slightly modified sketch lines.  File is 2022 ( I don't have 2021).
Message 7 of 9
cesarcoraini
in reply to: ToanDN
Thanks!!
Message 8 of 9
RDAOU
You do not really need to split the stairs ... it can go all the way as one run you just need to fix the inner turn and you should have a smooth spiral turn/return with structural depth 150mm
Message 9 of 9
cesarcoraini
in reply to: RDAOU
Thanks! That's the best option! Going to do that way.
Forma Design Contest
