U-shaped Ramp to Mezzanine
tstewart
Message 1 of 20
tstewart
Hw to draw a U-shaped ramp w/ landings to a Mezzanine level?
Replies (19)
Message 2 of 20
 Instead of building the Landing into the Winder, why not create a Floor at the Mezzanine Level and then place a U-Shaped Winder between the Level below and the Mezzanine Level?
Message 3 of 20
Alfredo_Medina
Is this an architectural question or a Revit-related question?
How can the observer know where the mezzanine level is to give any advice?
Message 4 of 20
tstewart
Revit question because the model is in Revit. The Mezzanine level is between the Ground & Second Floors.
Message 5 of 20
Your question, as I understood it, was how to include a Landing in the U-Shaped Winder. If this is something you really need to do, then Edit and Convert Winder to Sketch-Based and then sketch your Landing Boundary.
Message 6 of 20
tstewart
How to draw a U-Shaped ramp around the U-shaped Stair?
Message 7 of 20
Alfredo_Medina
Yes, mezzanine is in between first and second floor, but what is the distance that the ramp has to reach? Why don't you first draw the ramp in plan view and section with detail lines or reference planes? Once you get the architectural part correct, then you start the Ramp tool and click on points over your lines or planes in plan view.
Message 8 of 20
tstewart
How to draw a U-Shaped Ramp in plan? The landing is not correctly displaying and the height to Mezzanine is 12'.
Message 9 of 20
It is the same as drawing a ramp between any levels:
- Start a Ramp
- Specify Base and Top Level/elevation
- Specify Width
- Draw Runs (landings will be added automatically between runs)
- Adjust each Run's location and length
- Finish
Message 10 of 20
tstewart
Thank you and it worked.
Message 11 of 20
Alfredo_Medina
Again, this is an architectural question. You need to solve your ramp first with reference planes. Make sure it works, and complies with codes, etc. Then you use the Ramp tool or the Floor tool to do it.
For 12' rise and U-shape, you need a very long ramp with intermediate landings on each run, which probably does not fit in that space. That's why I suggest that you work all this yourself with planes, and see if it works.
Message 12 of 20
tstewart
Got it and the ramp is approx. 96'-144' which is what I figured. I wanted to make a U-shaped Ramp to cover that distance.
Thank you,
TS
Message 13 of 20
tstewart
How to draw multi-landings U-shaped ramp?
Message 14 of 20
RDAOU
@tstewart
Exactly the same as described in previous replies...instead of straight sketch it as a U.
Alternatively, you can place a U Shaped floor and modify its sub-elements
Note: this also would require that u sort out your ramp design to be aware of the heights ot needs to reach and at what slopes.that being said, a U shaped ramp around the posted stair will not comply with ADA codes or any other HCA codes... will be too steep and good to serve as a slide/conveyor
Message 15 of 20
tstewart
I wanted landings at each intersection and midway of ramp runs. Is that the same process?
Message 16 of 20
RDAOU
Yes the same...you just need to calculate the slope first in order to edit/create the appropriate ramp type. You need to input the desired slope and max run in the ramps type properties
Using a floor with edited sub-elements can make your life easier though you just need to input the elevations at each landing.. if u r not familiar with floor su-elements, see youtube below
https://www.youtube.com/watch?v=5YNccuzxmLs
Message 17 of 20
tstewart
Great solution and thank you.
Message 18 of 20
Alfredo_Medina
It does not seem to matter if things make sense, or if a ramp fits or not, or if it complies with codes or not.
Why don't you simply go to the help search in Revit and type "ramp". That will give you the steps, which seems to be all you care about. What is the point of starting a thread for this. All this conversation seems to be in vain, in my opinion.
Ramp:
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-3CCCB8E9-2ABB-495D-8B3E-079A4986D65C
Message 19 of 20
tstewart
The idea is sometimes better than the end result.
Message 20 of 20
Davidminkov_work
Only reasonable way to do it is with a floor that you edit afterwords to the desired levels, the ramp function is only usable for the most basic of ramps.
