'Type Mark' parameter missing in door family
skyeg321
skyeg321
I have this door family and the parameter 'Type Mark' is missing. I thought this was a built-in door parameter that could not be deleted? Does anyone know where it could have gone?
mhiserZFHXS
It doesn't show in the family editor, only in project.
Type Mark is a system parameter that only shows in projects.
syman2000
Instead of type mark, I would use Model as your parameter. That way it is easier for you to load the model type into the project.
HVAC-Novice
For type parameters I like to use a fixed value (and not something I set for each project). I created a shared type parameter. Your schedules and tags also need to use that shared parameter. That is the only way if you want to set it in the family for all future use.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
