Two Survey points
Two Survey points
eric.guizzetti
Message 1 of 21
Two Survey points
eric.guizzetti
Anyone seen this issue with 2020.1 where you have two survey points?
Replies (20)
Message 21 of 21
a_paynter
im having the exact same issue, i just started a new file from our office template, got the file setup, moving the Project Base point etc, when i noticed a 2nd Survey Point moving around aswell, named as "Survey Point - Project".
Opened up some older files, existing projects, and cant find anything to do with  "Survey Point - Project" anywhere?
It's just appeared out of nowhere
