Two Survey points
Two Survey points
eric.guizzetti
Message 1 of 21
Two Survey points
eric.guizzetti
Anyone seen this issue with 2020.1 where you have two survey points?
Replies (20)
Message 2 of 21
Two triangle icons? Do you have a Revit link?
Message 3 of 21
hmunsell
so you have Links in your model? one may be coming from a link.
  • VG > select "+" next to link > select Not Overridden
  • Check Override Display settings
  • select Custom
  • pick the Model Categories tab
  • under Model categories, pick Custom
  • scroll down to Site (select the "+")
  • uncheck Survey Point for that  link.
Howard Munsell
Message 4 of 21
eric.guizzetti
There is nothing linked in.
Message 5 of 21
Do you mean you are seeing this?
Message 6 of 21
eric.guizzetti
No Links
NO LINKSNO LINKS
Message 7 of 21
eric.guizzetti
I have no links in the model. NO LINKSNO LINKS
Message 8 of 21
eric.guizzetti
That looks exactly like what I am seeing. Keep in mind I have no models linked in.
Message 9 of 21
SteveKStafford
Close Revit, open, use Audit and open the file. Warnings? Does Review Warnings have any to report? What coordinates do these icons report when selected? Can you select both?
Steve Stafford
Message 10 of 21
hmunsell
can you upload the file?
Howard Munsell
Message 11 of 21
boyd_johnson
Any solutions to this?  Trying to understand what is going on as I'm finding similar occurrence.  I've removed all links and all worksets.  One Survey Point is noted as "INTERNAL" and the other is noted as "PROJECT".
Is this "INTERNAL" intended to not the internal origin of the original revit file?
If this is intentional, why in the world did Autodesk not create a different symbol for this third coordinate element?
Message 12 of 21
hmunsell
Can you upload the file with the issue for us to look at?
Howard Munsell
Message 13 of 21
Are you asking about the Survey Point's "Internal" designation which indicates the Current Site Name/Zero Origin that the Survey Point's Coordinates are relative to?
Message 14 of 21
boyd_johnson
sorry cant upload the files, it is a secure project.
@barthbradley  yes, it does sound like that and looks similar to your images.  Googling this topic I was able to find what the purpose is for these two survey points.  Sometimes I see two of them in a project, sometimes just the one survey point - what drives this behavior?
Does not appear to be a lot of documentation on this...and why is it not a different symbol?
Message 15 of 21
There can be multiple survey points in project, each presents a site location. Two is are the most common: one is Internal site location and the other is a shared site location. However, only one can be set as current at any given time so seeing two survey points in the same view doesn't make any sense.
You can save as to a new file, delete everything and share the file here.
Message 16 of 21
boyd_johnson
gone now after a resave and reopen...now I just see internal.
When would more than one survey point show up, after linking other revit files via shared coord.?  The files in questions have been provide by client and are established with lots of elements and multiple links (no longer found/attached).  I'm thinking the additional Survey point was residual from when multiple files were originally linked via a shared coordinate.
Maybe I'm missing something, but would think I could find more documentation on why there would be two survey points showing.
Message 17 of 21
Mohamed-Nassar
Close Revit and reopen it again may this disappear again.
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 18 of 21
@boyd_johnson: What I'm showing you in my screenshot is not two different Survey Points. I'm showing the same Survey Point located at different named Site origins. Sorry for the confusion.  A single Project can have multiple Shared Sites listed under Manage Tab=>Location Panel=>Site Tab.
Message 19 of 21
boyd_johnson
@barthbradley  thanks.  I think I need to read up more on this.   I looked at the Location under Site and it only listed one site...Internal but the view had two.   but it went away after a resave, close and reopen.
Message 20 of 21
hmunsell
was this the first time it has happened? did it only happen during that one session?
since it went away after a restart, maybe check to make sure your graphics driver is up-to-date....
Howard Munsell
