Message 1 of 8
Two rooms not showing in plan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I will do my best to explain the issue, but I have no idea what is going on. We are trying to place a room in floor plan, but when placing, revit does not show the "X" for the room's reference lines, and once placed, the Revit tells me the room is not visible in view. When I go into section or schedule, the room is visible (thouhg it is reporting the incorrect area, but thats a different issue. I can solve once the room is visible in plan...)
What I have already checked:
- Not a workset issue, in section, the room is the same workset as the ones that are visible
- It is not a filter. I created a completely fresh view and all the other rooms are visible except for the two in question
- It is not a height issue, in section i confirmed that the height is within the view range.
- It is not a phasing issue. All rooms are "Created in Phase 1"
Any other thoughts on what could be causing this?
