Turn a sheet into a revision 0 again
marco.defina
Message 1 of 18
marco.defina
i created my sheet with revision. How i can see in my sheet number the revision 00??
Revision 0 write nothing...
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
Accepted solutions (4)
Replies (17)
Message 2 of 18
Sahay_R
Can you share your titleblock family please?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 18
Do you even have Revision 0 entry under the Revisions list?
Message 4 of 18
marco.defina
attached the family.
No, i need? Where i can set revision 0?
Message 5 of 18
Message 6 of 18
marco.defina
i want not to see the revision 0 beacuse is the date of emission...
Message 7 of 18
Not understanding.  If you want the date then enter the date, if you don't then leave it blank.
Message 8 of 18
marco.defina
The revision 0 does not exist,because is the same of the emission date, and i don't want to see the revision 0 on the list of revision.
But i need the number at the end of the name of the sheet ".00"
Message 9 of 18
Share your family so we can understand where the value comes from.
Message 10 of 18
marco.defina
i shared in the previous comment...
Message 11 of 18
Sahay_R
Here you are -
Rina Sahay
Message 12 of 18
marco.defina
It does not work, if i set not visible on the Sheet i don't have ".00" revision on the name of sheet...
Ans second thing if i start with 0 numeric i have the first revision as 0...
Message 13 of 18
Sahay_R
Add in another revision for revision 1. Leave 0 blank. Or else when you have revisions, change the numbering to start from 1.
Rina Sahay
Message 14 of 18
marco.defina
The problem is to have the ".00" on the sheet when i have no revisions...
So if i understand what i want is impossible...
Message 15 of 18
Sahay_R
You have the 00. But you will also see revision 0 in the schedule. A thought - use text for the 00.
Rina Sahay
Message 16 of 18
Best I can do without adding visibility for an additional "0" is below:
Message 17 of 18
marco.defina
i don't want to see Revision 0 in the schedule!
If i create a revision .00 in the project, to see this number in the title block name sheet i need to set visibility of revision. If i set visibility of revision i see revision 00 in the schedule...It's a loop Smiley Wink
Yes i understand...So i cannot do in another way...The bad thing is that i cannot modify the schedule with filter...But with filter of visibility?
Message 18 of 18
Viveka_CD
Hi @marco.defina
Please see article on Revisions and About Revision Cloud Numbering (by Project or by Sheet)
@Sahay_R and @ToanDN have given the best possible workarounds.
If you find posts have solved or helped with your problem, please click on 'Accept as solution' to help others with similar questions.
