Trying to keep Muntins Centered on a double hung window
jwicks4MUNZ
Message 1 of 8
jwicks4MUNZ
I've been trying to add these 3x2 Muntins to the double-hung windows, but they don't stay centered whenever I change the window's height. I can get them to be the right size but not the proper placement. Does anyone know how to constrain them to the center? I can't seem to select a horizontal centerline.
Replies (7)
Message 2 of 8
RDAOU
@jwicks4MUNZ
You need to lock them and set the equalities shown in the below GIF. The amended .rfa file also attached
Contrain EQ of nested MuttinsContrain EQ of nested Muttins
Message 3 of 8
jwicks4MUNZ
That's perfect, thanks. How were you able to constrain the middle of the muntin? On my file, I can't seem to get the center of the mullion to lock to a reference plane. Further more how do you get the dimensions with the labels to show?
Message 4 of 8
RDAOU
@jwicks4MUNZ
You have to edit the nested family and change the Reference plane to Center (Elevation) or Weak reference. It was set to Not a Reference. Once you change it, you will be able to align and lock it in the host
Message 5 of 8
jwicks4MUNZ
Oh dang, that makes sense. But when did you connect the two "EQ." to?
Sorry for all the questions, just trying to learn how to do it myself haha
Message 6 of 8
RDAOU
All the below are new...new ref planes added to define the frame width (top/middle/Bottom)
The two purple circled dims were locked
All the other dims to the left for the EQ added (the ones with same color correspond to each other)
Message 7 of 8
jwicks4MUNZ
For some reason, it still doesn't seem to be working. I must be missing something.
Message 8 of 8
RDAOU
@jwicks4MUNZ
I did not check the window frame...from the pickture that looks like it hasnt been locked properly. Notice the bottom frame of the apper window panel and the top frame of the lower? they should be aligned but they seem to be shifting up and/or down based on ...i would assume frame width or some other parameters.
Edit: see below
The panel height as is will not always fit in properly... When the window height exceed a certain height and you change the frame height, you will end up with a gap that gradually increase between the two panels ...you need to introduce the Frame Width into that formula
Should I fix it and re-upload to this reply...or do you wish to test your mettel and give it a shot?
Edit: Here is it and new Family attached here
