Trying to Get More Realistic Renders, Currently Using RevitLT
jamesWGU2T
jamesWGU2T
Two quick questions.
1. Last few times i have tried to render to the revit cloud, the render comes back as one colour as if it started to render then gave up. Getting very annoying.
2. As i am a beginner/intermediate - is there a plug-in or a simple programme i can bring the revitLT model into to get more realistic renders? Or should i spend more time perfecting the materials I use. Not looking for super realistic but just better colouring.
Thanks.
James.
bill_gilliss
Doesn't sound right - I use cloud renders a lot, even with the desktop version available. Can you post a view in the Realistic visual style and cloud-rendered so we can see what you are dealing with?
Sounds like you haven't assigned Appearance Assets to the Materials.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
jamesWGU2T
see images attached
jamesWGU2T
Will spend a lot more time on this over the next week. The cloud renders are still an issue and have sent to autodesk.
bill_gilliss
"Arrival" looks okay. Is there something wrong with it?
I have no idea what might be causing the panoramas to look like that.
s.borello
try a 3rd party... better quality.
